There are 2 main hole sizes for down lights 70 / 90 mm How do I fix a 70mm hole to put 90mm light and 90mm hole to put 70mm light? It is plasterboard ceiling.
Thanks
Browse Forums DIY, Home Maintenance & Repair Re: Plasterboard rework for downlights 2Oct 19, 2014 10:31 am First you need a set a plasterboard hole saws (they are inexpensive) Drill the 70mm hole out to 90mm To repair the existing 90mm hole. Find a piece of plasterboard the same thickness as your ceiling (probably 10mm) and using your 90mm hole saw, drill a hole in it and keep the hole. Back block the existing 90mm hole with an offcut of plasterboard and then using the 90mm disc, glue this disc into the existing hole. Once the glue has set (leave it a couple of days) flush it and then you can then drill a new 70mm hole in it. Your main challenge is getting the plasterboard adhesive in small quantities. The smallest bags that I have seen of professional type adhesive/flushing compound are 10kg. Re: Plasterboard rework for downlights 4Oct 19, 2014 6:14 pm Quote: you can get a small 1kg bucket of ready to use all purpose plaster you can use it for everything. I have tried this. It is a drying compound not a chemically setting compound. I have found it is not strong enough to repair holes. My preference is the chemically (fast setting) compound however each to his own. Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7944 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2577 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4762 |
