Browse Forums DIY, Home Maintenance & Repair 1 Sep 04, 2014 4:01 pm Hey guys Got a friend that has a 600mm electric oven, installed under the hot plate stove Could it be the fuse? Not sure how those things sit in there. Do they just pull out or are they screwed in somehow? My friend who owns the oven said all the power in the house tripped out when it happened then noticed the oven not working Could be a blown fuse at the fuse box to? Re: Electric Oven Not working (Fuse?) 2Sep 04, 2014 7:31 pm I'd replace the ovens fuse or reset it at the fuse box. If it blows again call a sparky. Lower the door down and there should be a couple of screws through the oven frame into the surrounding panel. Then you can slide it out but unless you are a sparky and know what you are doing..... Have you read this recent thread ? viewtopic.php?f=16&t=72597 Stewie 2 4466 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 5192 Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 920 |
