Browse Forums DIY, Home Maintenance & Repair Re: HOT WATER SERVICE 2Sep 12, 2008 2:18 pm Just contact your local council and ask them to send you the requirments for instalation. Don't mention why, just get a copy and check it out before you go any further. Timbacare - Save Your Furniture! We can help you revive timber furniture & flooring www.timbacare.com.au Re: HOT WATER SERVICE 3Sep 12, 2008 5:33 pm I have seen many older houses here with HWS's in bathrooms or laundries, so I suppose you could have it in a sunroom.
Possibly your sunroom was once part of the back porch before it got enclosed? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24148 |
