Browse Forums DIY, Home Maintenance & Repair 1 Apr 04, 2014 6:58 pm Hi guys, I have a tear in the lead flashing which is causing a leak. It's situated between the dutch gable and roof tiles. I had it inspected and he thinks water is leaking through the crack, getting under the roof tiles and traveling down the sarking where it's causing water damage to the soffit. It has been siliconed up prior to me but is leaking again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've found Wakaflex Roofing Flashing Roll - Lead Free Adhesive Flashing Tape http://wakaflex.com.au/. It's lead-less flashing with an adhesive. Would it work from the underside of the existing flashing? Is there another way to fix the leak? Is there a tape I can use? Thanks. Re: Leaking/torn Lead flashing 2Apr 05, 2014 7:27 pm Hi TOL, just looking at pic above, for water to get to the sarking it would have to spill over the top edge of that tile which i think would be pretty obvious or theres a cracked tile under the lead. Did the person inspecting kick any tiles off above the soffit where the water damage is? this would give a clear indication if the water was coming down the sarking. I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10893 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6328 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10214 |
