Browse Forums DIY, Home Maintenance & Repair 1 Mar 16, 2014 2:19 pm Hi there, I'm buildings new home and have picked out my paint colours with the brand my builder uses. I decided that i would do the feature walls myself as my first DIY task as they were charging $200 per wall, so I thought I could beat that and I also hadn't decided exactly which walls I wanted coloured at the time. I've gone into Masters home improvement to look at getting everything I need in advance like a tray! paint brush, roller, tape. But I can't work out where I find the paint. How silly I must sound! I've managed to pick up the swatches, find a whole wall of the base paints from what I can tell.. But how do I get the colours I've picked? What am I missing here? I showed the staff my colours and he showed me the base I need, but I didn't buy anything he didn't tell me where to get the colours from and I felt way too stupid to ask. Do all the colours come made up in tins somewhere? Does anyone understand my ignorance and can clear it up for me?! Re: How to buy paint for feature walls 2Mar 16, 2014 5:03 pm You apply the base and then the paint colour you want over it, the Masters guy must have been astro travelling So when you choose the colour they should give you the correct base for the top coat as well. Re: How to buy paint for feature walls 3Mar 16, 2014 5:13 pm DIYnewbie Hi there, I'm buildings new home and have picked out my paint colours with the brand my builder uses. I decided that i would do the feature walls myself as my first DIY task as they were charging $200 per wall, so I thought I could beat that and I also hadn't decided exactly which walls I wanted coloured at the time. I've gone into Masters home improvement to look at getting everything I need in advance like a tray! paint brush, roller, tape. But I can't work out where I find the paint. How silly I must sound! I've managed to pick up the swatches, find a whole wall of the base paints from what I can tell.. But how do I get the colours I've picked? What am I missing here? I showed the staff my colours and he showed me the base I need, but I didn't buy anything he didn't tell me where to get the colours from and I felt way too stupid to ask. Do all the colours come made up in tins somewhere? Does anyone understand my ignorance and can clear it up for me?! I think Treechanger is getting confused between undercoat and base paint Basically you go to the counter and ask them for an amount of the colour you want. They then get a tin of that size of base paint and then add pigments to that base and mix them in, you finish up with a tin which is the colour you want. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to buy paint for feature walls 4Mar 16, 2014 5:49 pm What Bashworth said. That's what I meant...maybe I was actually astro travelling In other words they will tint the correct base to the colour you've chosen, whether it's a white based or a deep based colour. You can usually tell cos they have a W or D on the colour code. Clear as mud?? Read Bashworth again!!! Re: How to buy paint for feature walls 5Mar 16, 2014 5:58 pm So just to clarify, the paint counter people actually make the colour there using special ingredients as per the swatch, by adding to the base paint that I buy?! I think I actually get it now. They don't just have every colour of the rainbow sitting there waiting for people to pick out which is why I couldn't find anything I wanted/work it out. So the base paint isn't actually the paint you necessarily use for undercoats, it's a paint that has the colour added to it to reach the desired swatch colour. Plus therefore I need to buy a separate paint tin to be able to paint an undercoat too, which is different to above, but they can probably tell me which can to buy to make the wall neutral? Re: How to buy paint for feature walls 6Mar 16, 2014 6:10 pm Yes you have got the idea. You can get an undercoat, but if the wall is already painted it might be easy to just do multiple coats of the final colour. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to buy paint for feature walls 7Mar 16, 2014 7:37 pm You would need advice on the undercoat if the wall already has a deep based colour on it. For instance, I painted over a pink wall without an undercoat- I used 2 coats of new paint, but the pink still showed through! The paint shop told me I needed to neutralize the pink with grey paint, once I'd done this the new colour I'd chosen went on great. So the original wall colour can make a difference to what procedure you have to follow... Re: How to buy paint for feature walls 8Mar 17, 2014 9:37 am The painter should still do the undercoat as he will be painting all the walls with undercoat. He may even do the topcoat but in the same colour as the other walls. Then it's just a matter of buying a 4lt tin of your colour. I suggest looking up how to paint a wall on Youtube, seeing as you've never done it before. Good luck. Re: How to buy paint for feature walls 10Mar 18, 2014 10:00 am travelbug The painter should still do the undercoat as he will be painting all the walls with undercoat. He may even do the topcoat but in the same colour as the other walls. As i said in the other thread, putting on needless coats is bad painting practice. Let the painter do the undercoat, but DO NOT allow a pointless topcoat to be put on if you are just going to re colour it. Re: How to buy paint for feature walls 11Mar 18, 2014 3:30 pm qebtel travelbug The painter should still do the undercoat as he will be painting all the walls with undercoat. He may even do the topcoat but in the same colour as the other walls. As i said in the other thread, putting on needless coats is bad painting practice. Let the painter do the undercoat, but DO NOT allow a pointless topcoat to be put on if you are just going to re colour it. If the project builder is painting the whole house it may be easier to let him do just that rather than say don't paint this wall or this wall or that wall. Have you worked with tradies? Plus they may spray which will be more work to leave a few walls. Think outside the square. Re: How to buy paint for feature walls 12Mar 19, 2014 9:03 am travelbug If the project builder is painting the whole house it may be easier to let him do just that rather than say don't paint this wall or this wall or that wall. Have you worked with tradies? I get your point and I know some tradies are ignorant & make false promises in regards to what you want, but that is no excuse to defer to thir stupidity/laziness. Leaving off the useless top coat is beneficial to the tradie as well, as thats less work he has to do. So it is worth pressing home the point. travelbug Plus they may spray which will be more work to leave a few walls. lol nonsense. they dont have to mask it, it can cop the overspray. travelbug Think outside the square. Has nothing to do with thinking outside of the square. ITs has to do with making sure things are done properly (as i said before). IF you cant instruct painter that you dont want wall A or B topcoated, what chance have you got they will do anything right? I dont deal with tradies who cant follow simple instructions. Re: How to buy paint for feature walls 13Mar 31, 2014 5:18 pm You can go for two tone of the same colour specially the darker one for feature walls can look pretty good. Re: How to buy paint for feature walls 14May 21, 2014 3:28 pm If you felt ignorant i would like to know how that "paint expert" at Master feels! Paint comes in different bases which have certain amounts of Titanium White and each can will allow enough tinters to achieve your desired colour and still allowing it to cover well. In terms of undercoat, at times it is suggested to use a grey undercoat. More so when choosing Red shades. The "expert" at masters would have access to every colour which would prompt him to use a certain base. Should always be mixed on the spot unless they are out of the Base required. Your Job Simply should be to pick a colour. If covering a deep colour or applying a strong colour a specific undercoat may be required. hmmm id assume youll get hit with the "natural product therefore variation in colour etc" excuse. How bad are we talking? One could argue that if none of the displays or… 3 2454 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7006 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6062 |
