Browse Forums DIY, Home Maintenance & Repair 1 Mar 13, 2014 10:33 am As it says (: We have a sewer maintenance hole at the very back of our property. Several properties (including us) are directed to it. One of them has a pipe running all across our backyard and I think the (old) pipe is cracked and broken all over (high green grass tell-tale sign). Our small fruit tree located close to the centre of one section of the pipe is dying. So, who is responsible for fixing it? Syd Water or us? BTW, some years ago (before we built) we called them to investigate the cause of "sewage stink" right at the boundary line. They came with sophisticated equipment (spades), poked them around a few spots, went to chat with the neighbour, came back and concluded it's all in my head. Now we have this pipe clearly traced by grass across our land all the way to the maintenance hole - so the problem has worsened. What do we do? And why don't they do smoke test any more? Is poking bulky spades around the place and doing nothing all we can expect from SW (provided they don't blame us for the damaged pipes simply because we built new house and therefore we must have somehow cracked that pipe all around!!!)?? My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 2Mar 13, 2014 12:28 pm It really depends on who owns the pipe. If its Sydney Water they are responsible. If it only serves the neighbour its their responsibility although you may need to use the councils health officer to serve a notice. If more than the single neighbour discharges then its shared by all people who discharge to that pipe (if you are connected to that pipe you will be responsible for a share) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Broken sewage pipes across our property 3Mar 13, 2014 6:28 pm Thanks bashworth I found some diagrams and I'm pretty sure it's SW's pipes. I think they need to replace the pipe with the new plastic ones. However, can I ask them to make a slightly angled "bend" to avoid to dig right under our fruit tree? Or do they only ever do a striaght line (looks like it's always straight lines ) ?? My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 4Mar 13, 2014 7:01 pm If its Sydney Water's they may look at relining rather than digging up. If they are going to dig it up they 'May' avoid the tree. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Broken sewage pipes across our property 5Mar 14, 2014 7:02 am Thanks b. I guess I will have to call them ... but just not ready to have the yard all messed up from digging again I would prefer if they left the old pipe untouched and dig a new trench a bit further for the new pipe. But to avoid disturbing the tree too much, they would need to make an obtuse angle and I'm not sure they would do that. What is the depth of the sewage pipes, how deep would they need to place it?? My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 6Mar 14, 2014 7:24 am Lex, I don't know how things are organised in NSW, but in Victoria you can request a sewer asset plot from your water authority. There is a small fee but it shows you where the sewer is, how deep and what sort of pipe they have used. Worth having. I just requested it via our water authority's website and it was emailed to me within a couple of weeks. Re: Broken sewage pipes across our property 7Mar 14, 2014 8:17 am Thanks, Liliana I think we have a similar thing here in NSW - before we built and also after we built (for our own landscaping purposes), we requested all pipes for all utilities (gas, water, etc.) and I think it could have been via the Dial before you dig site. My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 8Mar 14, 2014 11:21 am Sewer pipes have to be laid with a minimum 1:60. A longer pipe run 'might' impact on the available slope. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Broken sewage pipes across our property 9Mar 14, 2014 11:52 am They cant deny and ignore a sewage stink if there is one. Did you press home the point properly? Sewers only stink when they are broken. You could get a smoke machine or somethign and put a bit of smoke down there yourself if you like, see if it comes up anywhere. Pipes are laid in straight sections, forget about your fruit tree. Main sewer lines are generally 1400mm or more deeper in SE Qld, Sydney I dont know. Re: Broken sewage pipes across our property 10Mar 15, 2014 10:34 am Thanks guys. I did give them an initial call ... long story short - I will call them to log a job when we have the time to be at home as this is considered "emergency"! Funny you should mention the stink - but as you can see from my previous posts, they did ignore it. I guess a good thing is that they could see that job in their system! And what do you mean forget about the tree?? Are the pipes really that deep??? Strange, as the person I talked to asked me if there is any soil subisidence over the pipe - as if the land that deep down could have moved so much so that the top sections of the pipe have collapsed - otherwise, I cannot imagine how can soil visibly subside unless something (ie. a shallow pipe) collapses considerably deep down in ground. If the pipe is only cracked, I can imagine it just leaks, but the soil around it should still be compacted enough (at that depth!!) so it doesn't really show on the very surface. Mind you, there is close to zero foot and other traffic in our yard! On the other hand, the cracks must be so prominent if the "stuff" is "fertilising" our grass to go visibly greener and higher all along the line!! My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 11Mar 15, 2014 10:39 am SaveH2O Sewer pipes have to be laid with a minimum 1:60. A longer pipe run 'might' impact on the available slope. Is it 60cm depth difference over 1m of length of pipe??? so if I start with 1m of pipe burried at 1m depth, the pipe would be only 40cm deep at the end of the 1m? My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 12Mar 15, 2014 10:44 am Don't talk in cm; no-one in the building industry uses them, it is always m and mm. Sewer 1:60 = 1m rise per 60m run of pipe = 100mm rise per 6m run of pipe = 16mm rise per 1m run of pipe Stormwater 1:100 = 1m rise per 100m run of pipe = 60mm rise per 6m run of pipe = 10mm rise per 1m run of pipe Stewie Re: Broken sewage pipes across our property 13Mar 15, 2014 11:28 am Lex Are the pipes really that deep??? Strange, as the person I talked to asked me if there is any soil subisidence over the pipe - as if the land that deep down could have moved so much so that the top sections of the pipe have collapsed - otherwise, I cannot imagine how can soil visibly subside unless something (ie. a shallow pipe) collapses considerably deep down in ground. If the pipe is only cracked, I can imagine it just leaks, but the soil around it should still be compacted enough (at that depth!!) so it doesn't really show on the very surface. You would be surprised at how much the ground can move. Soils are either reactive or dispersive. Reactive (clay) soil will rise and fall with increasing or decreasing sub soil moisture content and are a prime cause of house cracking and foundation subsidence. Dispersive soils can break down and seemingly 'melt away' when in contact with water. It is not uncommon for a broken pipe to create a large cavity in dispersive soil that can open up and consume part or all of a house, road or whatever else may be above it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Broken sewage pipes across our property 14Mar 15, 2014 11:34 am Just a couple of clarifications Generally public sewer lines serving properties are at least 1m deep (this allows the house pipes to be laid on a reasonable gradientnto reach the sewer) but can be 3-5m deep. Sewers serving large developments can be much deeper. The gradient of sewers depends on the diameter (larger pipes can have gradients of 1:100, 1:200, or even flatter) Sewers are designed to achieve a minimum velocity of flow rather than a particular gradient. I aim for a target velocity of 1m/sec. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Broken sewage pipes across our property 15Mar 15, 2014 11:47 am bashworth The gradient of sewers depends on the diameter (larger pipes can have gradients of 1:100, 1:200, or even flatter) Sewers are designed to achieve a minimum velocity of flow rather than a particular gradient. I aim for a target velocity of 1m/sec. Absolutely correct. Lex, I should have clarified that my previous post was referring to 100 mm DWV (sewer grade) pipe. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Broken sewage pipes across our property 17Mar 15, 2014 6:16 pm ooooohhh, where do I start ... I guess is a good point ... I did come across something else today - relining. But they need to dig a really big hole at the start and end points ... and that most likely means taking the fence down as well, since the neighbour's little lid is quite close to the fence (assuming all of this actually will be fixed, and fixed properly). The end point will need lots of excavation becuase that's where our own pipe joins the common pipe and then it runs into the access hole. BIG job (: And all the turf ruined. Who pays for that!?!? My signature is distracting people from my wise posts ... Re: Broken sewage pipes across our property 18Mar 15, 2014 7:32 pm Lex ooooohhh, where do I start ... I guess is a good point ... I did come across something else today - relining. But they need to dig a really big hole at the start and end points ... and that most likely means taking the fence down as well, since the neighbour's little lid is quite close to the fence (assuming all of this actually will be fixed, and fixed properly). The end point will need lots of excavation becuase that's where our own pipe joins the common pipe and then it runs into the access hole. BIG job (: And all the turf ruined. Who pays for that!?!? There are all sorts of Relining one method used is Cured in Place Pipe (CIPP) which is quite common and requires little or no excavation. This is a link to one company (http://www.insituform.com/Water-Wastewa ... mCIPP.aspx) you will find a video on the top right of the page. There are several variations of this method offered b different companies. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Thanks for clarifying. Sorry I misunderstood your point 7 7400 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 13643 4 5169 |
