Browse Forums DIY, Home Maintenance & Repair 1 Nov 19, 2015 11:24 am Hi we have just bought a home that was built with Hebel Blocks and I want to attach a pull out clothes line to an outside wall. Can this be done with Hebel Blocks, if so what is the procedure. Thanks for any advice. Regards Daniel Re: Attaching to a Hebel Block wall 2Nov 19, 2015 2:18 pm The Hebel Technical Manual Part 5 PDF might help find a solution. http://hebeldocs.myspec.net.au/specify.php?&id=1996500117 Re: Attaching to a Hebel Block wall 3Nov 20, 2015 10:19 am Hi thanks for the link, I'll have a read. Cheers Daniel DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6315 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 785 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5912 |
