Browse Forums DIY, Home Maintenance & Repair 1 Mar 04, 2014 3:14 pm There is gap appearing between window frame(exterior) and brickwork .Any one have any suggustion on resolution? Thanks Re: Gap between Window frame and brickwork 2Mar 04, 2014 5:31 pm ShirleyMei, do you have any pictures of how big the gap is? I think there might need to be a gap for expansion. I know in our last rental the window pane in the bedroom cracked from one side to the other and I blamed my son for hitting it with a football but the glazier said the builder had not left any expansion room for the window frame. Re: Gap between Window frame and brickwork 3Mar 04, 2014 5:35 pm It could well be an articulation joint. This allows both expansion and some flexing of the slab. Where articulation joints are next to a door or window a gap of 10 mm must be left between the edge of the frame and the brickwork. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Gap between Window frame and brickwork 5Mar 06, 2014 6:46 am Instructions below copied from this link: viewtopic.php?f=6&t=42169&p=1106642&hilit=+how+to+post+a+photo+#p1106642 "go to this website - http://www.photobucket.com sign up first upload photos copy the photo link post to homeone forum" 2 7514 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8005 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11227 |
