Browse Forums DIY, Home Maintenance & Repair 1 Nov 15, 2013 11:27 pm We have laid pavers 5 cm apart with stones between. Road base (compacted) underneath and mortar was used to secure each paver in place. The issue is now that all the pavers are laid and stones in place, they seem to be quite wobbly and rocky when u walk on them. Does anyone have any advice or tips on how to fix this problem? Looking for a solution preferrably that doesn't require us to pull them all up and re-lay We were thinking sand or some mortar between the pavers to keep them from rocking, but just not sure if it will work and would like a avoid wasting time. Any thoughts would be appreciated. Thanks Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18579 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13781 |
