Browse Forums DIY, Home Maintenance & Repair Re: Moulds in walk in closet 15Apr 29, 2014 1:37 am Jason_Jetten Quote: Yes, heater is nonsense, we're still finding out, there must be a bigger problem... no insulation maybe. We're purchasing a dehumidifier in the walk in plus the exhaust fan in the bathroom which we will keep running whenever we uses the room and the bathroom. Sometimes we leave the door open. We're also cleaning the area little by little where molds are forming..unfortunately there's only one small window in the walk in. I think this is the right solution to your problem. In the past we also experienced the same problem. Our closet was just next to the bathroom and we also live in very wet area, so the first thing we did was to buy dehumidifier. We use it for other rooms too and it is really effective. The exhaust fan also helped us and right the situation is much better. Only from time to time ( once in a few months) there are some build ups but we remove them right away and it's OK. Hope these steps will help at your situation, too. Yeah it did helped us too.. it has solved the persistent mild damp in the walk in closet. if clothes were left in my clothes rack for several months they would start to grow mould. I left our dehumidifier, i have ion612 running for 8 hours on high mode while at work and it collected 1.8 litres of water. On the low setting, it is quiet still so not disturbing when i sleep Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 6673 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3815 |
