In the bathroom is mold inside the wall. How can I remove it?
Browse Forums DIY, Home Maintenance & Repair Re: mold inside the wall 2Nov 10, 2013 7:56 pm This could be more than just mould, you should invest in professional inspection and a report. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: mold inside the wall 4Nov 11, 2013 7:36 am You need to stop the mould forming in the first place by insulating the walls and ceiling then installing a ceiling fan to extract all the moisture laden air to the outside when you use the shower. I also think that it looks more like you have a leak from above which I think is what B-E above is alluding to. Edit : Ha, you beat me to it qebtel ! Stewie Re: mold inside the wall 5Nov 11, 2013 8:31 am What if it's a termite nest? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: mold inside the wall 7Nov 12, 2013 6:12 am Yes that highlights trying to get get a solution over the internet from someone that hasn't seen it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: mold inside the wall 9Nov 12, 2013 8:31 am jackp On this side of Australia (WA), no one builds a house out of wood. What holds the roof up? Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: mold inside the wall 10Nov 12, 2013 10:43 am jackp On this side of Australia (WA), no one builds a house out of wood. Got news for you. http://www.realestate.com.au/property-h ... -113724903 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16157 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
