Browse Forums DIY, Home Maintenance & Repair 1 Aug 27, 2013 12:24 pm Hello, It's been a while since I've been on these forums, I've started reading and now thought of all of these things I should do around the house. To the initial reason I came here though. The plaster around our entrance door has reached the point where I really need to do something about it, I've patched up walls before, but I thought because there is obviously more forces at work here than a regular wall there might be a better product to use instead of regular wall putty. Perhaps something with a little bit of flexibility. Any suggestions before I head to bunnings would be greatly appreciated! Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building with RedInk at Waterhall in WA, check out our blog: http://justinandashlyshouse.blogspot.com/ The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8054 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 |
