Does anyone know how to remove the kind of tap handle below?
There are no screws / nuts that I can see anywhere.
Any help would be greatly appreciated.
Browse Forums DIY, Home Maintenance & Repair Re: Can't remove tap handle (No screws) 2Jul 27, 2013 4:19 pm You should be able to unscrew the lever from the body of the handle and then you can pull the handle off. That's how mine work. HD Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1546 l spoke to my plumber we decided to replace the rusted screws and keep all the screws with no rust, it will only cost a few hundred 7 8750 |
