Browse Forums DIY, Home Maintenance & Repair 1 Jun 23, 2013 6:26 pm Hello, I just recently bought a house and I've just noticed the two brick columns in the garage have cracked away from the outer wall. How bad is this and what's the best way going about fixing it. The columns don't seem to bear any weight of the beam that runs across the top of them due to a small air gap between the beam and the top of the column which allows the bricks to be moved slightly. I was thinking of cementing or builders bogging behind the bricks then running an anchor through the column into the outer wall but if there's a better way please let me know. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick columns 2Jul 11, 2013 4:30 pm Perhaps a glued wedge driven into the gap between the column and beam? Arfur 4 3738 2 8359 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12127 |
