Browse Forums DIY, Home Maintenance & Repair 1 Jun 15, 2013 2:29 pm We have a Rheem Stellar gas hot water service. From the day we moved in the hot water temp has never been great ~43 degrees C. We brought this up with our "builder" at handover and 6 month maintenance and got fobbed off with a story about how they weren't allowed to adjust the service to give a higher temp. It's already set to max on the gas burner. Anyone got any ideas of how to get a higher temp say 50 degrees C? Re: Hot water not hot 2Jun 15, 2013 6:24 pm Sounds like your tempering valve does needs adjusting up. A properly working one can be adjusted up to the 50 - 58 max - depending on which brand it is. We had our plumber adjust ours up to its 55 degree max. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Hot water not hot 3Jun 22, 2013 10:34 am Thanks, this is what I suggested to DAH when we did handover but they flat out refused to get the plumbers back. Guess I'll have to get a plumber in - seems there's no end to fixing Dale Alcock's poor work. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24148 |
