Browse Forums DIY, Home Maintenance & Repair 1 Jun 10, 2013 7:08 pm Hi - Our house is fully Hebel rendered - Today I was cleaning it as it says you should here : http://hebel.com.au/Pages/FAQs.aspx I successfully cleaned mud and dirt from all of the surfaces except the window sills, which (perhaps as they are horizontal) seem to be going mouldy, and the hose pipe would not blast it off. Any ideas as to how to get rid of the mould would be appreciated. I have previously also tried blasting it with the Gerni, but thankfully only did this in a small area as it blasted some of the render off won't be trying that again. Warm soapy water might be my next try. thanks I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5871 1 6601 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6173 |
