Browse Forums DIY, Home Maintenance & Repair 1 Apr 18, 2013 5:14 pm Recently I've been noticing hot water coming out yellow. It's not too bad yet but as compared to cold water, it is slightly yellow. I tried samples from kitchen and bathroom. They are both yellow. Is it a problem with my water heater? If yes, is there a way to clean it? It's a "Rheem" brand and I don't know if I can open it. I have no idea how old it is. I am thinking of turning the inlet water off and emptying the heater but I don't think it will clean it up completely. Re: Hot water comes out yellow. How can I fix this? 2Apr 18, 2013 5:21 pm I'm guessing it might be rust? If so, I don't think there's much you can do other than replacing your hot water system. Is the unit inside the house or outside? When the same thing happened to us, the unit (which was inside a cupboard in our laundry) starting leaking from its tank shortly after from one of the seams of the tank (which had all gone rusty), and the water actually made its way under the wall and into one of our bedrooms. Just something to be aware of, hopefully you don't experience the same Re: Hot water comes out yellow. How can I fix this? 3Apr 19, 2013 8:31 am sbryzak I'm guessing it might be rust? If so, I don't think there's much you can do other than replacing your hot water system. Is the unit inside the house or outside? When the same thing happened to us, the unit (which was inside a cupboard in our laundry) starting leaking from its tank shortly after from one of the seams of the tank (which had all gone rusty), and the water actually made its way under the wall and into one of our bedrooms. Just something to be aware of, hopefully you don't experience the same Thanks for the advice, Shane. The water heater is inside our unit, in the laundry. I guess I have to consider replacing the heater if there is not much I can do with fixing it... Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6543 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 |
