Browse Forums DIY, Home Maintenance & Repair 1 Apr 15, 2013 8:12 pm hey hey, don't know if any can help but... we have a very old house on the gold coast. The old copper piping is rusting and subsequently the water out of the taps is discolored and not very good to drink (even with a filter). Does anyone know if it's fairly straightforward to run some sort of new plastic/rubber pipe from the mains that our house is attached to, to the house itself? (we don't mind if we have to run the pipe along the top of the yard and the house is on stumps so it's easy access to the piping under the house. I think the piping under house is fairly recent so no need to replace that) Re: replacing old copper water pipes myself 2Apr 16, 2013 7:40 am The first thing would be to find out if you are permitted to do such work in your area (as you were told at Whirlpool). If you are not permitted why not negotiate with the plumber to save costs and dig the trenches yourself. Running (UV stabilised) pipework above ground will give you hot water as the pipe bakes in the sun Its not hard to run copper piping provided you have an oxy set, however your cheapest and easiest option would be to run pvc pressure pipe to the house, following all the guide lines on depth required (was 300mm is SA to avoid garden forks etc) and propper preparation of joints. You could leave points for future irrigation lines etc, but do your homework first. Arfur DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5117 Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4514 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 |
