Browse Forums DIY, Home Maintenance & Repair 1 Apr 14, 2013 1:36 pm I have recently taken my old split level air conditioner from my house and put it at my mother's house. I've had an electrician/plumber install it onto her house but have noticed after a couple of days that it is leaking oil from a pipe leading into the unit. Now I don't know much about air condition systems and before I call the guy to come around and have a look I want to know if its something that I would be able to fix myself. I also want to ask if there should even be oil leading into the system. Photos are attached below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It is leaking from the valve where the hand is pointing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Split System Air Conditioner Leaking Oil? 2Apr 14, 2013 11:48 pm tighten it up if it leaks more get the ac guy to repair and check gas as it can get out from that leak Hurry up and wait I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1931 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
