Browse Forums DIY, Home Maintenance & Repair 1 Mar 25, 2013 8:45 am I was looking to get my light switches replaced with the saturn range but they are just so expensive. Is there regulations governing light switches as you can get similar products from china at 10% of the cost. Re: Touch Light switches 4May 07, 2013 10:03 pm I think its better to use trusted brands and not those affordable ones. Make sure to use quality materials which are proven to be safe and secure. Do not risk your security, prioritize the effectiveness and efficiency of materials specially when used at home. Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3074 Shelly switches require a paid subscription for full access to all features which is ridiulous given the lifespan of a home and if you were to sell it or buy a home with… 2 4532 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11707 |
