Browse Forums DIY, Home Maintenance & Repair 1 Mar 09, 2013 9:34 am We've almost finished but realise the doors on the built-in in our bedroom (3rd) take up a wider area than we thought. Is there an easy way to convert to sliding doors (floor is slab) ? Any ideas on a cost for conversion to sliding ? Sliding would give us quite an extra bit of room to play with. Cheers ! Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 2Mar 09, 2013 9:35 am I'm talking about when you open the doors. Other options welcome ... Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 3Mar 10, 2013 11:42 am C'mon you carpenter types - is there an alternative etc. Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 4Mar 10, 2013 11:47 am Do you currently have hinged doors on metal frame? One possibility, you could take out the doors and frame, get a plasterer in if you have hardball just to patch everything and tidy the walls up (could do that yourself if your in the know), then you could put in a pair of vinyl sliding doors in. You would be looking around a grand approx for that suggestion. Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 5Mar 10, 2013 12:14 pm My mom had standard doors on her wardrobes and had them converted to sliders, we have double brick houses here in WA so they installed a new frame around/over the existing door frame. It is now a much better use of the space. Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 6Mar 10, 2013 1:23 pm bkm2009 Do you currently have hinged doors on metal frame? One possibility, you could take out the doors and frame, get a plasterer in if you have hardball just to patch everything and tidy the walls up (could do that yourself if your in the know), then you could put in a pair of vinyl sliding doors in. You would be looking around a grand approx for that suggestion. For the suggestion .... ... or the work ... Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 7Mar 10, 2013 1:25 pm fmac My mom had standard doors on her wardrobes and had them converted to sliders, we have double brick houses here in WA so they installed a new frame around/over the existing door frame. It is now a much better use of the space. Yes - ours is a standard built-in. Hinges etc and two opening doors. Might need new doors ? Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 8Mar 10, 2013 2:59 pm Thats what she had. They put in a new frame and sliding doors and she got rid of the standard ones Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 9Mar 11, 2013 6:32 am The doors and tracks are the expensive bit. Not much cheaper than a whole new wardrobe. As others said. Just put tracks and doors. Get one of the built in wardrobe mobs out to quote. But you may need a carpenter to change surrounding timbers where hinges etc are. Difficult without a photo. Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 10Mar 11, 2013 6:37 am travelbug The doors and tracks are the expensive bit. Not much cheaper than a whole new wardrobe. As others said. Just put tracks and doors. Get one of the built in wardrobe mobs out to quote. But you may need a carpenter to change surrounding timbers where hinges etc are. Difficult without a photo. Thanks. Yes - I feel it might cost a bit. Re: Built-ins - Doors - Sliding - Utilisation of Bedroom spa 11Mar 11, 2013 7:39 am I'm now thinking of glass mirror doors - within the exisiting frame. They might be a tad smaller but would open to either end and I'd just need to "fill" in the hinge marks. I'd put the frame for the new doors inside the old frame line. we have a standard size and often we have a lot of variety to choose 0 3575 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5039 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 |
