Browse Forums DIY, Home Maintenance & Repair 1 Mar 03, 2013 12:04 pm Hi, We've had a problem since the house was built 3 years ago that on hot days boiling hot water comes out of the cold water taps. It can take up to 5 minutes running the water before the hot water finishes and cold water starts again. We have a tin roof, and live in WA. We think the cold water pipes in the roof are plastic. Any ideas on how to fix this problem?? (we don't want kids getting scolded). Thanks!! Re: Hot Water Coming Out of Cold Water Taps on Hot Days - He 2Mar 03, 2013 12:13 pm We had this problem. Look in the roof at where your water pipes run. The plumber had run the pipes up and over beams (lazy) so they were close to the roof. There were VERY warm. You could wash up in the water. If that is the problem move them or insulate them. Re: Hot Water Coming Out of Cold Water Taps on Hot Days - He 3Mar 03, 2013 4:47 pm AS/NZS 3500.1:2003 SECTION 2.4.1(d) states that cold water pipes and fittings shall be protected from ambient heat. This standard unfortunately is ambiguous as it does not state a maximum temperature, however, The Plumbing Regulations 2008 states, “Drinking water that is not intentionally heated must be delivered at a temperature of less than 40 degrees Celsius.” I have linked a Victorian Plumbing Industry Document for your benefit. I know that you are in W.A. but the information will help you. http://www.pic.vic.gov.au/resources/doc ... _taps2.pdf A roof cavity can reach 85 degrees C on a 35 degree C day and you effectively have a heat exchange happening. As to what can you do to fix it? Easy! The install is not compliant and your house is only 3 years old. Demand that it is fixed! Whoever installed the piping should have known better and it obviously was not inspected. Good luck. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Hot Water Coming Out of Cold Water Taps on Hot Days - He 4Mar 04, 2013 2:33 am Quote: Demand that it is fixed! Good luck with that. As a retired plumber I have run copper cold water lines in the ceilings of hundreds of homes/units, as is in my own home, built over 35 yrs ago. It saves corrosion or damage in the ground and is easier to add to eliminating ripping up paving etc. From experience, running (copper) services in the roof is little different to replacing old corroded in-ground pipework by laying it on top of the footing, exposed to temperature extremes. EDIT: I very much doubt if it would be hot enough to scald your children and I seriously doubt it takes a whole 5 minutes to run cold Arfur Re: Hot Water Coming Out of Cold Water Taps on Hot Days - He 5Mar 06, 2013 9:03 pm Uncle Arfur - I get the same problem and it might not take 5 but it takes a good 3 minutes for the water to cool down. As for so hot it could scald children - I don't have kids but I do know I don't even put my own hands under the running water until it has cooled down. Built with RedInk Custom 5000 Key Handover 15/12/2009 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12698 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 8192 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2661 |
