Browse Forums DIY, Home Maintenance & Repair 1 Feb 05, 2013 4:16 pm Hi everyone, Apologies if I haven't found the right spot for this, but here goes.... A few weeks ago a cold water mains PVC pipe split just above its joint to a copper elbow leading to the cold water intake on the HWS. Luckily it was reasonably accessible. Thinking I didn't have the tools (ie crimper) to fix it I got a plumber to come out. He replaced the split section using joiners fairly similar to those you'd use on your garden hose, which is fine but of course I could have done that myself. Anyhoo about a week later the pipe burst again, the old hose about 2 inches above the fix. Thus nothing to do with the plumbers work but how unlucky eh? SO this time I fixed it myself using a longer piece of new pipe and the clamps/fittings used in the previous fix. Job done. Until today when the old pipe, about an inch above the fix burst AGAIN. Each time it's been when the washing machine's on which I initially thought was the culprit but the last 2 times I've had the cold water dialed right down to relieve any of those "pressure surges" solenoid's can create. In any case the mains should be able to handle it and for it to burst 3 times in the same spot is really weird. The pipe was fixed to the framing pretty well and not rubbing against anything. Why has it done this?!?! Now i've replaced about a 4m section with the join in the roof. The only idea I had was that that part of the pipe that failed might have had some manufacturing flaw that resulted in the 3 ruptures. going 4m's back I'm hoping that this will be the end of it but i'm scared of it happening again in a) the roof of b) elsewhere in the plumbing. The plumbings 8 years old. Any advice guys? Sean Re: Repeated burst mains water, any plumbers? 2Feb 10, 2013 7:50 pm PVC pipes are not crimped. Elbows are not copper. shorns76 a cold water mains PVC pipe split just above its joint to a copper elbow leading to the cold water intake on the HWS. What do you mean by the above as pipes do not have joints? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Repeated burst mains water, any plumbers? 3Feb 11, 2013 9:57 pm shorns76 split just above its joint to a copper elbow leading to the cold water intake on the HWS. Luckily it was reasonably accessible. Thinking I didn't have the tools (ie crimper) to fix it I got a plumber to come out. He replaced the split section using joiners fairly similar to those you'd use on your garden hose, which is fine but of course I could have done that myself. Anyhoo about a week later the pipe burst again, the old hose about 2 inches above the fix. Thus nothing to do with the plumbers work but how unlucky eh? SO this time I fixed it myself using a longer piece of new pipe and the clamps/fittings used in the previous fix. Job done. Until today when the old pipe, about an inch above the fix burst AGAIN. OK, you are talking about a pipe AND a hose. I have a suspicion that you might be referring to PB hose. If it is PB, then your reference to copper and crimping now makes sense. You are experiencing the same problem and this tells us something. Might have something to do with using the same fittings again...maybe; what do you think??? What fittings did the plumber use? Were they the same ones? You should have phoned the plumber rather than do it yourself...TWICE! PB hose has been a problem in the U.S. and the symptoms are as you describe. The splits have generally been traced back to improper installations where some plumbers used old brass fittings. The crimper must be properly calibrated as the hose must not be crimped too tight. Crimp PB too tightly and it can split and this will happen near the joint. This is what you have described as happening with your crimped "PVC pipe". Having had failures at one point, the entire install should be deemed suspect. My guess is that it was either crimped too tight (most likely) or the fittings are suspect. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4192 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5811 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12784 |
