Browse Forums DIY, Home Maintenance & Repair Re: Lintel repair 4Jun 13, 2013 7:47 am Quote: When you say "remove a couple of bricks " ....and replace bricks you mean under the ends of lintel right Yes. Remove as much or as little as needed so you can slip the lintel in. Stewie DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6539 DIY, Home Maintenance & Repair The intent of that sort of clause is being misaaplied. its suposed to be used to avoid paying out for things liek when you decided to do a reno yourself and the… 3 5523 |
