Hi there, want to create 2 long shelves (about 1300mm wide) to go into a plaster wall and hold some very heavy books and a pot plant etc.
I was looking at some Hafele supports that hold up to 300kg which is more than enough. My question is in regard to the
Can I get away with 2 supports (one at either end), or 3. The studs are evenly spaced apart, so 3 would look nice, but the shelf supports are $35 each so I'd rather use 2.
What type of thickness should I use?
