Browse Forums DIY, Home Maintenance & Repair 1 Apr 10, 2008 9:07 am Hi guys,
I have a question about the townhouse we currently live in. A few years back when we first moved in we noticed areas of the ceiling were appearing damp and water was coming through (dripping) when it rained. We had some people out who determined it was coming from the upstairs balcony, they claimed to have fixed it but occasionally we still get the odd bubbling under the ceiling plaster and the areas have changed colour to a sort of off yellow - which I'm guessing might be mould... They came out to paint over it about a month ago and I have just looked up and sure enough the old yellow patch is back... Is there anything we can do to get rid of it....Im worried for my children health wise and also it doesn't look nice, I thought painting over it would have done the trick but it has just come through again.... Any help would be great Cheers Bel Re: Ceiling Mould 2Apr 10, 2008 9:14 am I think it is only the black mold that you need to worry about but worth checking. Get them to come out and fix it again. Re: Ceiling Mould 3Apr 10, 2008 9:39 am 3timesbuilda I think it is only the black mold that you need to worry about but worth checking. Get them to come out and fix it again. BUZZZZ Your concerns about mould are quite justified. Definitely demand they return (or better still, a more competent contractor. The damp area should be measured with moisture meters to determine dryness. They should not have painted over unless they had a positively dry surface. Kepp plenty of ventilation to the room, and have child sleep in other room if you can. Ash. Re: Ceiling Mould 4Apr 10, 2008 9:39 am If it keeps happening it could be that the balcony membrane has failed, or there isn't one installed. We had a similar issue at a Body Corporate that we managed and it turned out to be that a membrane had not been installed and it leaked every time it rained.
A plumber should be able to do a leak detection test which should show if it is the membrane or another underlying issue. Dana -------------------------- Building with DFH - carpet installed! Re: Ceiling Mould 5Apr 10, 2008 11:49 am Thanks everyone!
Kryten - Ours is a body corporate lot of townhouses in Newport, I wonder if it is the same one I'll definatly give a local plumber a call....they did come and rip up all the balcony tiles and put new ones down - we haven't had any further roof leaks but the yellow patch won't go away Ash - Its not in the kids bedrooms - but the main living area so just as bad. I just googled ceiling mould and it said ventilation is the key - I have all windows open - I just applied some diluted bleach to it too and the yellow colour is gone 3xb - Originally it was dark in one patch but after they 'fixed' it and painted it cmes back yellow... Thanks again guys Re: Ceiling Mould 6Apr 10, 2008 12:04 pm proper course of action;
1. Investigate to determine where & how water is getting in. Fix it. 2. Measure moisture with moisture detection instruments. 3. Dry any wet materials (either allowing to dry naturally or by assisted drying). 4. Repair any damaged materials & paint. Typically, a plumber will only address 1. A qualified water damage restoration technician is worth having in to address 2 and 3. Ash. Re: Ceiling Mould 8Apr 10, 2008 12:28 pm Many carpet cleaners are trained in WDR, but not all. You could look in the yellow pages, and look for carpet cleaners that are qualified in WDR.
However, you shouldn't have to. If you are renting, it should be your property manager that arranges the appropriate tradies. Ash. Re: Ceiling Mould 10Apr 11, 2008 7:24 pm Bel
I would report this to your Body Corporate manager - the internal damage should be covered under the Body Corporate's insurance policy. I would also get the manager to check the strata plan, as some balconies I have come across before are not noted as part of the title and are technically a Body Corporate responsibility to repair. If it is on the title, the cost to repair will unfortunately be your cost, howver the insurance will still rectify the water damage. Either way, the insurance company will send someone out to check the damage and the underlying cause and will advise what needs to be done to rectify the leak. HTH Dana -------------------------- Building with DFH - carpet installed! Re: Ceiling Mould 11Apr 11, 2008 7:33 pm Yep….tell them to stop buggering around by painting it, that’s not going to fix or help anything!
Tell them you want it fixed! Maybe a leak in the roof tiles. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28320 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5943 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
