Browse Forums DIY, Home Maintenance & Repair Re: Ceiling Mould 11Apr 11, 2008 7:33 pm Yep….tell them to stop buggering around by painting it, that’s not going to fix or help anything!
Tell them you want it fixed! Maybe a leak in the roof tiles. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2456 |
