Browse Forums DIY, Home Maintenance & Repair 1 Nov 30, 2012 10:15 am Hi, Some assistance would be really appreciated. I have leaking toilet base. It's not siliconed to the floor (obviously) but nor is it bolted (as far as I can tell - in fact, until I put a piece of plastic under it, it would rock back and forth). Should I simply silicone/seal the base, or is that just storing up trouble. Note it isn't built into the wall, essentially free standing other than the water inlet from the wall. Thoughts on what to do? There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2436 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3037 I have seen poly marble shower bases last in excess of 30 years 1 4491 |
