Browse Forums DIY, Home Maintenance & Repair 1 Sep 20, 2012 8:59 pm Can anyone tell me what would be the best product to use for brightening up some poorly neglected outdoor wooden furniture (not sure what sort it is, possibly teak/cedar)..A friend mentioned Linseed Oil...however I thought that was something that was used many years ago... I prefer not to varnish as this will then peel and need redoing...some kind of stain/oil would be better I think..but i would hate for a guest to sit on a chair and have greasy/marked clothes... Any suggestions warmly welcomed... Cheers Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: Anyone got tips for revitalising outdoor wooden furnitur 2Sep 20, 2012 9:20 pm I have been told to use a 50/50 mix of linseed oil and turpentine on my gates to keep them looking oiled. Maybe try a test patch first underneath or something to see how it looks. Re: Anyone got tips for revitalising outdoor wooden furnitur 3Sep 20, 2012 9:47 pm Cheers thanks Titch, I will give it a go... Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE If so what were the "special circumstances" under which it was granted? "Note: If the development consent is for 'dual occupancy' an owner-builder permit can only be… 0 14216 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9211 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7290 |
