Browse Forums DIY, Home Maintenance & Repair 1 Aug 27, 2012 9:25 am Hello, I've patched up a few holes in the wall. Now for repainting it. Is it better to get the colour matched from the old plaster, or go use the specific colour which is on the tin? The ceiling was last painted 2 years ago. Re: Paint over a patch 2Aug 27, 2012 10:23 am After 2 years you will find the difference between whats on the walls and ceiling fairly significant and unless you want the patches standout like the proverbial you will need to colour-match or repaint the whole surface. Why not try a small hidden area? Arfur Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6181 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15244 |
