Browse Forums DIY, Home Maintenance & Repair Re: Your advice please on slipping roof tiles 10Jul 11, 2012 5:53 pm Brockie . I will try to use a rubber mallet and a piece of wood to get my tiles back where they should be and check where the batons are before deciding if I need to pass the job on to a roofer. Thanks for your help. Be careful trying to do the work yourself. We had a tile roof problem and the long guarantee by the tile company became invalid because the previous owner got up and tramped all over the roof, breaking tiles as he went. Had there only been a registered roofer doing the work the warranty would still be in effect. It's pretty easy for a company to see that an amateur was at work. Why don't you call the manufacturer and get recommendations for proper roofers to take a look? Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2155 Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest… 2 1951 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15298 |
