Browse Forums DIY, Home Maintenance & Repair 1 Jun 30, 2012 5:04 pm I have changed a lot of tap washers but have come across these taps that have no cover over the usual top nut/screw. They are cheap plastic style ones around 20 years old. When I wind them out all the way I can just see a spot where I could slide a very thin spanner, under the plastic handle to undo the whole tap assembly. There are no allen keys or small grub screws anywhere to be seen. I'm contemplating just breaking the plastic handles off so I can get to the Spindle and just fit new taps but hate admitting defeat.. Here is a pic of the thing...Ugly hey.. [url] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/url] Re: Old kitchen taps with no top screw. 2Jul 01, 2012 1:05 am These are old Raymor T4 vandal proof taps, and yes they are UGLY. Tradelink is a stockist and I think owner of the brand See -- http://www.raymor.com.au/ItemsPage.asp? ... ncT-Series And scroll way down -- http://www.raymor.com.au/SpecManual/SectD.pdf From memory the head is screwed to the skirt immediately below it. Grasp the head and undo the skirt. From there it should be obvious how the skirt is attached to the spindle and how to remove the lower flange. Then its plain sailing Arfur Re: Old kitchen taps with no top screw. 3Jul 01, 2012 3:59 pm That was it, the star part unscrewed from the skirt, then it was a simple flat head screw and the usual set up. Thanks heaps, it was doing my head in.... If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8317 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24696 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31280 |
