Browse Forums DIY, Home Maintenance & Repair 1 Jun 27, 2012 11:09 am Hi everyone, i hope this is the correct area to post this. We are getting a new walk in robe installed and I have to now remove the single shelf with hanging rail installed by the builder (In Perth, single brick wall). I have looked high and low and cant see any screws which makes me beleive they have just nailed this straight into the wall. Does anyone have any tips or advice on how to remove this? Thanks. Re: How to remove shelf from walk in robe installed by build 2Jun 28, 2012 10:43 pm Remove quad above shelf (if any) then remove shelf itself. Next give the shelf rails a solid whack with a hammer and the fixings should become evident. It is probably screwed or mailed intro plastice plugs in the brick wall. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: How to remove shelf from walk in robe installed by build 3Jun 29, 2012 11:05 am Thanks for that, will give it a try. most towels and sheets will fit easily on 300mm deep shelves and my suggestion allows for a counter surface under the window (about 90cm off the floor would be a… 1 2208 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 1057 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 4027 |
