Browse Forums DIY, Home Maintenance & Repair Re: Attaching stacker stone to wall 2Apr 18, 2012 5:12 pm What sort of wall is it? Landscape Design & Construction http://cherub.squarespace.com/ Re: Attaching stacker stone to wall 4Apr 18, 2012 5:21 pm Stacker stone is usually glued with tile adhesive. Must check weight issues if going over certain height. May need to use villa board or similar fixed as specified. Landscape Design & Construction http://cherub.squarespace.com/ Re: Attaching stacker stone to wall 6Apr 18, 2012 5:41 pm Use villa board fixed Min 200mm centres mechanically fixed, check on weight of stone if over 32Kg sqm may need to reinforce frame work. Check with stone manufacturer for there specs. Landscape Design & Construction http://cherub.squarespace.com/ DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6235 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 752 Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3993 |
