Browse Forums DIY, Home Maintenance & Repair Re: Attaching stacker stone to wall 2Apr 18, 2012 5:12 pm Landscape Design & Construction http://cherub.squarespace.com/ Re: Attaching stacker stone to wall 4Apr 18, 2012 5:21 pm Landscape Design & Construction http://cherub.squarespace.com/ Re: Attaching stacker stone to wall 6Apr 18, 2012 5:41 pm Use villa board fixed Min 200mm centres mechanically fixed, check on weight of stone if over 32Kg sqm may need to reinforce frame work. Check with stone manufacturer for there specs. Landscape Design & Construction http://cherub.squarespace.com/ DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6240 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 772 Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7906 |
