Browse Forums DIY, Home Maintenance & Repair 1 Mar 01, 2008 6:36 pm Hi Guys,
The other day I went to a home open to get some renovation ideas and I saw that the exterior of the house had been clad in what appeared to be white timber boards. Closer inspection revealed that it was in fact thin plastic cladding which had been moulded to appear like timber boards but was in fact one large continuous sheet which had been cut to size. It looks like an ideal product with which to cover the ugly rendered asbestos my house is currently clad with but I have no idea what this product is and I cant find it in any of the large hardware stores. Does anyone have any idea of what it is called, where I can find it and what it costs? It looks like it would be quite an economical solution to concealing ugly cladding. The plastic was quite flexible and appeared almost thin enough to be cut with scissors (almost) so I imagine it would be easy to install myself. If no one has any idea what I am talking about, can anyone recommend a product that is easy to use to cover the outside of a house which is economical and attractive? We dont want to have to pay to have all of the asbestos removed to have genuine replacement cladding installed, and painting would be a last resort as the exterior of the house would require a lot of filling and crack-concealing work. Any advice would be greatly appreciated. Re: External Cladding Questions 2Mar 02, 2008 7:33 pm You can clad over fibro with any type of cladding, whether it is timber, plastic, fibre cement or composite cladding. Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5656 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12071 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11123 |
