Browse Forums DIY, Home Maintenance & Repair 1 Feb 08, 2012 9:28 pm Just moved in our new property which completed 3 months ago and found there is crack/gap between the cornice and gyprock, as well as gap/crack between floor tiles and wall. What caused those issues? Are these just need maintenance or something like structural issue e.g. slab movement? I have attached two photos below. http://i1106.photobucket.com/albums/h369/umehomes/DSC_0050.jpg http://i1106.photobucket.com/albums/h369/umehomes/gaporcrackbetweentileandgyprock-1.jpg Please share what you think. Thanks heaps Re: Crack found at cornice and floor tiles 2Feb 21, 2012 3:52 pm New homes can settle after moving in but it looks like their has been movement in the walls. I would contact your builder to come and fix. There should also be silicon between the tiles and the wall, if it is just grout it will show if there is any movement. Craig Re: Crack found at cornice and floor tiles 5Apr 13, 2012 8:14 am it is normal to have crack like this for a new house, take photo with timestamp and make a record, get builder back to do maintenance work. if the crack gets bigger over time and will not stop, get yourself an independent inspector first and do a review, weaponize yourself with an independent report before going to the builder. Re: Crack found at cornice and floor tiles 6Oct 27, 2012 5:13 pm Hi all, just reviving an old thread. After having keys for 14 months, we have noticed a crack has developed in the bathroom wall tile (joining onto a window corner). What right do we have to get the builder to replace and fix as they normally have a 6 month warranty only. thanks for any help regarding the matter. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9298 The photo is not really clear but to me it looks like twist in the cornice. Slight anticlockwise rotation at the top of the cornice and slightly clockwise at bottom should… 8 8467 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15833 |
