Browse Forums DIY, Home Maintenance & Repair 1 Jan 23, 2012 5:39 pm Hi, My builder put in a plastic 600 x 600 x 600 stormwater pit to divert the stormwater from the side of my house. The pit has been installed directly into clay soil. I believe that this would warp the pit in time as the clay soil will expand. Any thoughts on this anyone? I thought about digging around the pit and filling it with concrete, but am not sure if I am going overboard. Re: Plastic stormwater pit 2Jan 25, 2012 2:47 pm you just need to make sure whatever you do (pave, concrete, other) is solid enough to hold its shape. Ours are plastic and we just concreted around them(mask them up so no conc goes in the pit or blocks the gate) and they are fine. Re: Plastic stormwater pit 3Jan 31, 2012 2:24 am no_idea The pit has been installed directly into clay soil. I believe that this would warp the pit in time as the clay soil will expand. I thought about digging around the pit and filling it with concrete, but am not sure if I am going overboard. I understand your concern as I dont like these (cheap option) plastic pits, preferring concrete poured in situ. From my experience the reason the top grating is so heavy is to stop the plastic walls collapsing inwards. Concreting around yours could help but what about the base? Arfur DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6451 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10484 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4923 |
