Browse Forums DIY, Home Maintenance & Repair 1 Dec 21, 2011 3:50 pm Hi All, I had a building inspection done on my house, and apparently the internal walls are all horse hair plaster. I would like to hang a clock on the wall, however it is made of glass and is at least 2-3Kgs. Without being able to find studs etc in the wall, how else can I hang the clock? I have tried the heavier sticky hooks, only to find they fall very easily and very quickly. Any help would be great thanks Re: Hanging clock on Horse Hair plaster wall 2Dec 21, 2011 4:40 pm Use the nail-type hooks? http://homerepair.about.com/od/interior ... ning_3.htm Arfur Re: Hanging clock on Horse Hair plaster wall 3Dec 22, 2011 9:35 am Uncle Arfur Use the nail-type hooks? http://homerepair.about.com/od/interior ... ning_3.htm They look Ok, however Im hesitant to try if Im not sure they will last with my plaster type... Re: Hanging clock on Horse Hair plaster wall 4Dec 22, 2011 3:46 pm Interested in the look of these, I wonder how they would go? http://www.scrooz.com.au/products/gripr ... -of-5.html Re: Hanging clock on Horse Hair plaster wall 5Dec 23, 2011 4:54 am hambo12 Uncle Arfur Use the nail-type hooks? http://homerepair.about.com/od/interior ... ning_3.htm They look Ok, however Im hesitant to try if Im not sure they will last with my plaster type... They work well in gyprock and should in fibrous plaster unless its a hundred years old and crumbly, perhaps you could fix one and test it using a weight on some string? If not then you will need a toggle hook that spreads behind the plaster, something like this -- http://www.alibaba.com/showroom/toggle- ... -hook.html Available at Bunnings Arfur Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5059 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5306 Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13496 |
