Browse Forums DIY, Home Maintenance & Repair 1 Oct 14, 2011 10:30 am I need to mount two garden taps on a single mains outlet. I might have seen somewhere a brass Y-piece that would be perfect for that, but I can't find on the net nor in Bunnings. I've got a garden irrigation multiplexer, but it's no good for what I need. Any plumbers out there, who could give advice how best to do it ?? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to multiplex the garden tap?? 2Oct 14, 2011 10:35 am Look in the garden irrigation area of Bunnings rather than the plumbing section. I have bought several over the years. Make sure you get a quality one some of the cheaper ones have porous castings and leak The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How to multiplex the garden tap?? 3Oct 14, 2011 5:40 pm its def in bunnings I bought one from the bunbury outlet and I also saw them at the clarkson one so prob at a few. Mine were hanging up on one of those racks rather than on a shelf at the end of the tap/ retic section. And although I explained what I wanted stated the name of the product. and they could find it on their computer they weren't able to spot it for me. I managed to find it myself eventually. this is the one I bought. It's made by Ladco and is called an add-a-tap Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's Fu showing one in situ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's the thread where I was looking for it http://forum.homeone.com.au/viewtopic.php?f=19&t=27687&hilit=tap+adapter&start=60 Can't tell you how well it works as DH has so far refused to install it. Re: How to multiplex the garden tap?? 4Oct 16, 2011 10:40 am kexkez its def in bunnings I bought one from the bunbury outlet and I also saw them at the clarkson one so prob at a few. Mine were hanging up on one of those racks rather than on a shelf at the end of the tap/ retic section. It's made by Ladco and is called an add-a-tap Thanks Kexkez, that's just what I wanted, but.... I've searched Bunnings in Morley for 1/2 hr, looking for it. The innocent young thing I've asked about it couldn't find it, so I've decided not to waste any more time and bought: 1 t-piece, 1 elbow, 1 threaded nipple. Here's the result: http://i330.photobucket.com/albums/l413/kristofw/DSC00004.jpg Quote: Can't tell you how well it works as DH has so far refused to install it. Well, maybe it's the time for an enterprising gal to grab a few tools, some thread tape and show DH up Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to multiplex the garden tap?? 5Oct 16, 2011 10:44 am I wish. They are HIS tools and he's convinced me if it goes wrong and the tap brass ends up upside down it would be a drama to sort out. hence his reluctance to fit the damn thing. Getting a plumber here to fix it would be an issue if it went pear shaped. Re: How to multiplex the garden tap?? 6Oct 16, 2011 3:47 pm kexkez I wish. They are HIS tools and he's convinced me if it goes wrong and the tap brass ends up upside down it would be a drama to sort out. hence his reluctance to fit the damn thing. Getting a plumber here to fix it would be an issue if it went pear shaped. Hmmm, fitting that Y-piece and the taps is easier than fixing a leaking tap valve. I'm no plumber and doing that stuff in the pic took me less than 20 minutes. There's an old Polish proverb that roughly translates to: the eyes are afraid of the job, but the hands will know how to do it. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How to multiplex the garden tap?? 7Oct 16, 2011 3:55 pm well he replaces values happily enough. I guess it's a matter of need. he doesn't see the need yet. thanks Re: How to multiplex the garden tap?? 8Oct 16, 2011 4:11 pm Hi All, If you are at the Morley Bunnings then go to where the retic timers are and the Y fittings are on teh opposite side about 3 meters down. They have the same ones and also ones where each spout has a little tap already, that way you can just add it on. Hope you find it if you are still looking but your way also works.... Maybe KIV for next time Ciao Mark Re: How to multiplex the garden tap?? 9Oct 16, 2011 8:25 pm Hi Guys, Had a brass 4 way adaptor on our prev home for years. Something similar to: http://www.nrrbs.com.au/hosenetabrass.htm or http://www.cyclone.com.au/products/cyclone-4/multi-outlet-adaptor Just screws onto existing garden tap. Got a life, just can't find it! Re: How to multiplex the garden tap?? 10Oct 16, 2011 9:55 pm nrh157 Hi Guys, Had a brass 4 way adaptor on our prev home for years. Something similar to: http://www.nrrbs.com.au/hosenetabrass.htm or http://www.cyclone.com.au/products/cyclone-4/multi-outlet-adaptor Just screws onto existing garden tap. These usually provide reduced flow with a narrower opening . where as the ones that Kris and I showed you get full pressure though. The 2nd one would be like the 2 way posted earlier by me or Kris's version. Except the one I showed you can actually add a full tap handle to each end so you can have both or one on or off that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7537 7 5212 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6806 |
