Bathroom Leaking Problem
Just found out that there are water slowly leaching out of the grout between the tiles outside of the shower (just next to the shower)
The bathroom is upstairs, there is no sign of leaking/water damamge downstairs as yet.
What could it be the problem? and who should I call to inspect?
would a plumber do? but if it involves tile job shall I also call a tiler?
Just want to get it fixed...
Thanks heaps
It could be something as simple as your grout allowing water ingress, or your tap flanges in the shower are not sealed to the tiles, or a gap between your shower screen and the tiles, or worst scenario it could be a water pipe leak within the wall.
A good plumber would pin-point the problem
Is the water coming out of the wall tiles or the floor tiles? Is the floor a concrete floor or a timber floor and how old is the bathroom?
Regards,
Simon
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks…
11/08/2023
12
I don’t think so as the floor area over 300 square meters then it is class 3….
