Browse Forums DIY, Home Maintenance & Repair Re: Light globes keep blowing 7Jan 11, 2008 10:08 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Light globes keep blowing 17Aug 02, 2008 1:29 pm This problem won't have anything to do with input poweror voltage fluctuations. It is only one light fitting which is playing up, so the supply is irrelevant.
The problem will be either in the fitting itself or the wiring to it. Cheers beach beachsides Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11694 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17356 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19987 |
