Browse Forums DIY, Home Maintenance & Repair Re: Best way to clean white Polish porcelain tiles 2Jun 21, 2011 8:19 am The best way is to use a neuteal pH7 cleaner you can find this these cleaning products at any cleaning suplply shop. If your tiles are heavily soiled than I recommend a high pH 12.0 tile and grout cleaner, after use thoroughly rinse the floor repeat the rinsing process than for maintenance use a neutral cleaner. If you would like anymore info check out my website. Re: Best way to clean white Polish porcelain tiles 3Jul 14, 2011 12:11 pm great. any products with neutral ph that are readily available like in the supermarket or at bunnings? Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: Best way to clean white Polish porcelain tiles 4Jul 14, 2011 12:27 pm Shops or hardware stores do not sell a neutral cleaner you will find this cleaning product at a cleaning supply shop. Most hardeware stores only sell high alkaline and acid products. Craig Re: Best way to clean white Polish porcelain tiles 5Jul 14, 2011 12:54 pm you'd wonder why the supermarkets/hardware stores don't if that's the recommended thing to clean the tiles with?? Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: Best way to clean white Polish porcelain tiles 6Jul 14, 2011 1:53 pm Yes you are not wrong. The main reason is that neutral cleaners do not clean floors that well if they are already heavily soiled and stained. If the shops sold a neutral cleaner most would take it back because what they really need to restore their tile and grout is using a high alkaline cleaner first 12.0 pH than they should use a neutral cleaner 7.0 pH for maintenance afterwards. This way the floors will stay cleaner longer using a neutral cleaner. Keep in mind if you use a high 12.0 pH alkaline cleaner than you will have to rinse the floors and repeat the rinse to remove any residue if not the floor will get soiled very quickly. If using a neutral cleaner the floor does not have to be rinsed. Craig Re: Best way to clean white Polish porcelain tiles 7Jul 14, 2011 2:04 pm so true G P,I found supermarket cleaners discoloured grout Re: Best way to clean white Polish porcelain tiles 8Aug 29, 2011 10:23 pm Ask you local cleaning supplier. Its the aplicator that you use that can make all the difference. Have Fun. Cool Hand Lukes Re: Best way to clean white Polish porcelain tiles 9Sep 01, 2011 12:18 am We too have white (off-white) polished porcelin tiles. For the first big clean after handover I used the Sureseal Sure Clean Porceling Cleaner, which you can buy at most tile shops. It worked beautifully on our tiles. And now I just use a steam mop, but the thing is I have to dry it by towel afterwards to avoid the water marks appearing! That part is most painful, but the outcome is beautiful glossy tiles. I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 636 4 9060 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1665 |
