Browse Forums DIY, Home Maintenance & Repair 1 May 08, 2011 4:10 pm Hi guys, I think i may have bought the wrong paint...i bought the British Paints Ceiling Paint Flat Acrylic --- is this for CEILING ONLY?? or can i use it to paint the walls as well?? - i know it's good for wet area's - but is it ok for living room etc??? I bought a 15L tin as well 0.0 Regards Michael Michael Chan | Australia wide Mortgage Broker Michael@ShapeHomeLoans.com.au | 1300 74 5626 | Fax: 02 8212 8909 http://www.ShapeHomeLoans.com.au Re: British Paints Ceiling Paint Flat Acrylic 3May 13, 2011 9:32 pm try it and see? they make the flat paint for the ceilings for some reason to do with the light reflecting up there or something... but I don't know of any reason other than cosmetic that it can't be used on walls too. if you like it you might as well use it. as far as I know we have the same paint in our wet areas as living areas. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: British Paints Ceiling Paint Flat Acrylic 4May 13, 2011 9:41 pm Thanks for reply- On the first day, i did a sample test in a small area- my conclusion DONT USE IT ON THE WALLS!! Because- Ceiling paints: 1.Get's dirty easily 2. Not easy to clean - Can not simple "wipe off" 3. Very rough surface, feels a bit like " very fine sand paper" lol I asked the Bunnings guy, and he said pretty much the same- it's flat paint so not easy to "clean" ....i guess that's why it's Ceiling paint; whats the chances you will dirty or touch the Ceiling??? unless you have a food fight. Regards Michael Michael Chan | Australia wide Mortgage Broker Michael@ShapeHomeLoans.com.au | 1300 74 5626 | Fax: 02 8212 8909 http://www.ShapeHomeLoans.com.au Re: British Paints Ceiling Paint Flat Acrylic 5May 14, 2011 11:22 am shape Thanks for reply- On the first day, i did a sample test in a small area- my conclusion DONT USE IT ON THE WALLS!! Because- Ceiling paints: 1.Get's dirty easily 2. Not easy to clean - Can not simple "wipe off" 3. Very rough surface, feels a bit like " very fine sand paper" lol I asked the Bunnings guy, and he said pretty much the same- it's flat paint so not easy to "clean" ....i guess that's why it's Ceiling paint; whats the chances you will dirty or touch the Ceiling??? unless you have a food fight. Regards Michael Pass the paint please I do not have a ceiling like yours Re: British Paints Ceiling Paint Flat Acrylic 6Aug 28, 2011 8:09 am shape Thanks for reply- On the first day, i did a sample test in a small area- my conclusion DONT USE IT ON THE WALLS!! Because- Ceiling paints: 1.Get's dirty easily 2. Not easy to clean - Can not simple "wipe off" 3. Very rough surface, feels a bit like " very fine sand paper" lol I asked the Bunnings guy, and he said pretty much the same- it's flat paint so not easy to "clean" ....i guess that's why it's Ceiling paint; whats the chances you will dirty or touch the Ceiling??? unless you have a food fight. Regards Michael Hi Micheal, I am a professional painter, Ceiling paint or flat acrylic paint have good hiding properties and are generally used for ceilings or areas where there are defects that need covering up. As stated above they they are not as easy to wash/wipe down as washable low sheen paints but could be used if you choose to do so. Ideally if you have small children this is not ideal. There are brands on the Market such as Dulux Wash & wear which have good repealing properties and hold up well to constant cleaning, if you use a premium interior low sheen paint you wont have any issues with cleaning . Re: British Paints Ceiling Paint Flat Acrylic 7Mar 18, 2012 9:16 am It could just be that it's British Paints. They are my least favourite Bunnings paint. We did a feature wall with them and it took more coats and was harder to work with than either Wattyl or Dulux Today is under construction. Thank you for understanding. Re: British Paints Ceiling Paint Flat Acrylic 8Mar 19, 2012 1:35 am Excalibur is correct. Ceiling paint is for ceilings and brand has nothing to do with it. The main offenders for dirtying ceilings are electricians, A/C installers and anyone who uses the manhole to accesses the roof space. What concerns me is your described 'gritty' feel of the finished test-paint, or didn't you prepare the surface at all? Or have a dirty/cheap/perished roller? Dirty brush? Arfur The yellowing mainly occurs to white or very light colours. 1 2923 Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I… 12 18024 Suggestions please for acrylic rendering Color to match austral brick urban one pepper. Pic for reference. Thanks 0 5063 |
