Browse Forums DIY, Home Maintenance & Repair Re: Ceiling water stain 4Apr 12, 2011 10:59 am Probably a roof leak, or could be possums wetting? Check it for sure. Re: Ceiling water stain 9Apr 12, 2011 12:54 pm you need to get in the roof and see were the water comes from. Note it rarely comes directly above the stain, water usually follows beams and trusses along their length from a higher point. See if you can track the water line. Re: Ceiling water stain 11Apr 12, 2011 3:30 pm Paint an oil or metho based stain blocking undercoat, then 2 coats of ceiling paint Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3667 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 |
