Browse Forums DIY, Home Maintenance & Repair 1 Feb 08, 2011 4:09 pm The strappings under my house are iron, mostly nongalvanised, which I inherited from the original owner. There's so much rust on them that they've caused divots in the iron. I used Ranex Rustbuster after removing the bubbles, but I cooked it too long and there's white powder on them now. I've tried to remove the powder with a damp cloth and then a dry one. The white comes back. Should I be concerned or simply paint over them with primer then paint? The company does not recommend a zinc based paint but that's different from saying it's prohibited. Will the rust bubbles just come back if I do use a zinc based paint with a primer? I feel like I'm fighting a losing battle as the strappings continue to get chewed up. Re: Removing Rust/Painting Iron Strappings Under House 2Feb 09, 2011 4:33 pm Could these strapping be gradually replaced one at the time with galvanised steel? Can they be cut with angle grinder? I say that because you only see the surface and not underneath that could create at lot of problems in the near future. Re: Removing Rust/Painting Iron Strappings Under House 4Mar 04, 2011 12:04 pm hey , what you could do is use a steel etching primer, what it does it etch into the steel much like acid etching concrete. it "should" allow for maximum adhesion for top coating. before you prime it i would use a wire brush to give it a clean down hope this helps Glenn Re: Removing Rust/Painting Iron Strappings Under House 5Mar 04, 2011 2:56 pm Glennb hey , what you could do is use a steel etching primer, what it does it etch into the steel much like acid etching concrete. it "should" allow for maximum adhesion for top coating. before you prime it i would use a wire brush to give it a clean down hope this helps Glenn - S & A Painting What about the non visible and hard to reach parts? Steel is steel and still rusts (carbon steel content) unless it is of a non corrosive grading but I doubt there is its cost would be expensive. There are some chemicals available to remove and coat rusts but I doubt they would work right in this case You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7167 THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28123 Very common on rendered homes Smaller suppliers get the lower quality raw materials 6 11924 |
