Browse Forums DIY, Home Maintenance & Repair 1 Feb 20, 2011 8:49 pm We need to make repairs to our leaking tiled 1st floor balcony, caused by hairline cracks in the mortar joints. I've heard of a firm in Sydney -- N.J. Sampson P/L -- they have a chemical solution to waterproof the tiles -- but don't know anything about their reputation. We also have calcium leaching from the edge tiles. Has anyone else used them or any other firm who can waterproof the tiles and halt the efflorescence? http://www.njsamson.com/index.php?optio ... ticle&id=1 Thanks... Re: Repairs to leaking tiled balcony 2Mar 10, 2011 6:42 am Don't know of them But you can not seal the tiles unless they are stone or quarry. As for your white powder it is a salt attack coming out if the concrete slab due to water damp and the drying out. It will cause your tile adhesive to fail and go drummy The leak will be causes from failed or no waterproofing ad you would be aware We use a product that is a Migrating microporosity transpiration sealer which creates a chemical reaction not only in the grout but the substrate and tiles if they are stone or concrete based sealing them to a depth if about 26mm does not change the colour of the material applied to Carries a 25 year warranty is uv stable ad it us not a plastic based sealer. No cheap and need to be an approved to even buy it If you do get someone to seal it make sure it is not a film sealer otherwise you will be doing it again in 12 months Re: Repairs to leaking tiled balcony 3Mar 10, 2011 11:22 am "..But you can not seal the tiles unless they are stone or quarry.." ours are an Italian vitrified tile. The builders did put in a waterproof base, not sure what type, but I guess it has simply failed over time -- the deck faces west, so cops a hiding from the elements. "..The leak will be causes from failed or no waterproofing ad you would be aware We use a product that is a Migrating microporosity transpiration sealer which creates a chemical reaction not only in the grout but the substrate and tiles if they are stone or concrete based sealing them to a depth if about 26mm does not change the colour of the material applied to Carries a 25 year warranty is uv stable ad it us not a plastic based sealer...." err .. did you mean to put in the name of the product you recommend? We will definitely be looking for an approved waterproofer to do this work for us. Thanks for your advice! Re: Repairs to leaking tiled balcony 4Mar 25, 2011 2:58 pm thanks but we have now arranged for a waterproofing company to attend to this problem. The topic can now be closed. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4890 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4939 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2545 |
