Browse Forums DIY, Home Maintenance & Repair 1 Feb 11, 2011 8:52 am Hi, Quick intro before I get down to my question, have been in my house for 16 months, lots of things I need to do, but as with any project it is time and money. My big problem right now is with a couple of mice deciding that they like my house. I have check where they could be getting in and it is behind the oven where the gas pipe comes out of the wall. I have read that steel wool or expansion foam can be used in holes, but what I need to know is; is it safe to use these around the gas pipe at the back of the oven and if not what can I use? Also Bait in the roof cavity, would this be a good idea? Thanks Heaps Re: Hello & Help 2Feb 11, 2011 4:41 pm I would go for the foam which I have found good. Safe to use in this application. In a rental house were we had mouse problems I found that bait in the roof cleared them out for about a year. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Hello & Help 3Feb 11, 2011 4:47 pm Bunji Hi, Quick intro before I get down to my question, have been in my house for 16 months, lots of things I need to do, but as with any project it is time and money. My big problem right now is with a couple of mice deciding that they like my house. I have check where they could be getting in and it is behind the oven where the gas pipe comes out of the wall. I have read that steel wool or expansion foam can be used in holes, but what I need to know is; is it safe to use these around the gas pipe at the back of the oven and if not what can I use? Also Bait in the roof cavity, would this be a good idea? Thanks Heaps Definitely add the baits in the roof cavity!! And under house if appropriate I used steel wool around the pipes, although there are special collars you can get that fit the hole and block the rest but I don't know how good they are. We did use some expansion foam but it looks really messy at least the way we did it Re: Hello & Help 4Feb 12, 2011 6:14 pm If the hole isn't too big, use no more gaps, that expanding stuff makes a mess and whatever you do don't get it on your hands. Definately use baits as well and check them every now and again. Living in my Burbank terrace at Aurora A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5806 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7929 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12508 |
