Browse Forums DIY, Home Maintenance & Repair 1 Feb 09, 2011 6:40 pm Hi Don't know if anyone can help with a problem with our Dav%y toilet pump which pumps water to flush toilets. It is itermittently switching itself on and off when there no demand for the water (ie the toilet has not been flushed). We've noticed this mainly at night and it's driving us nuts. Any suggestions of what causing the problem would be appreciated. Many thanks Flew Re: Dav%y pumps for the toilets keeps going on it's own 2Feb 09, 2011 6:44 pm U could need a new pressure switch for the pump? Otherwise u may have a leak Re: Dav%y pumps for the toilets keeps going on it's own 3Feb 16, 2011 3:44 pm pressure pumps i have found cause cisterns to let water pass due to the pressure. check the pressure switch or even put a pressure limiting valve on the line to suit manufactor specs Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 6011 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 784 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 73769 |
