Browse Forums DIY, Home Maintenance & Repair 1 Jan 28, 2011 9:27 pm Hi Guys, Rain water leaking into garage from neighbours property via left brickwall. Its a relatively new house on concrete slab. The problem is because this house is lower than neighbours ground level. The garage is on the left boundary line of the block so cant do retaining wall. The neighbours are cooperative to allow digging from their side to my slab level and do some kind of waterproofing and may be also allow to put a agi drain. Is rendering to required (2-3) courses of bricks a good solution? What will be the best waterproofing application, product and where for this problem? Appreciate any help. Re: Rain water leaking into garage 2Jan 29, 2011 8:18 am I would use a bituminous paint possibly with a sheet of UPVC builders film pressed onto the final coat while it was still wet. You need to continue the waterproofing to at least 100mm above ground level. Here is a link to a supplier of the bituminous paint http://www.crommelin.com.au/waterproofing.php The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Rain water leaking into garage 3Feb 01, 2011 9:07 am Your neighbor is responsible for water that leaves their block and enters yours. It has nothing to do with being cooperative, although that helps. Your wall should have cement sheeting (2layers) and plastic sheeting as a minimum. As Bashworth said, bituminous paint will help too. You or Your neighbor will need to install AG drains along the wall and connect to appropriate outlet. I'm not sure who will be responsible for this cost. Hard to say. Re: Rain water leaking into garage 4Feb 01, 2011 9:32 am Is the garage wall a single skin wall, I'd be tipping to use an elastomeric coating, it doesn't have to be the black stuff, there are easier to use products on the same site BW posted. Where you are coming from is where you are going to... DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1668 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18805 |
